Dec 03, 2025
Using the Claude Agent SDK with Koyeb Sandboxes for Secure Code Execution
The Claude Agent SDK makes it easy to build autonomous agents that can write files, run commands, and maintain conversational state. These agents can iteratively improve and correct their own work as they operate, often running as long-lived processes that maintain and evolve their internal state over time.
But giving an AI agent the ability to execute code also means it can end up doing things you did not intend. It might run commands you did not ask for, read or write files outside its scope, consume more resources than expected, or interfere with other workloads on the machine it's running on. These are the typical risks associated with running untrusted code directly on a host machine.
To keep your infrastructure safe, agents need to run inside fast, fully isolated, sandboxed execution environments that isolate their filesystem, network, processes, and resource usage from the rest of your environment.
In this guide, we will show how to use the Claude Agent SDK with Koyeb Sandboxes, which provide fast, scalable, fully isolated environments for safely executing AI-generated code by building a minimal autonomous agent running inside a Koyeb Sandbox.
  • A Koyeb account to create Sandboxes
  • A Koyeb API key to create and manage Sandboxes
  • A Claude API key from Anthropic to use the Claude Agent SDK
  • Python 3.10+ installed on your machine
  • uv installed on your machine to manage Python dependencies
To complete this guide and build a minimalistic AI agent running inside a Koyeb Sandbox, you'll need to follow these steps:
  1. Create a new project
  2. Install project dependencies
  3. Create the Script to execute code in a Koyeb Sandbox
  4. Set up local environment variables
  5. Deploy a Koyeb Sandbox and run the Claude Agent SDK powered agent
To get started, on your local machine, open a terminal and navigate to a location of your choice to create a new project directory:
mkdir claude-agent-sdk-with-koyeb-sandboxes
cd claude-agent-sdk-with-koyeb-sandboxes
Inside the project directory, create a new Python project by running the following command:
uv init
This initializes a new Python project and creates the main.py and pyproject.toml files.
With the environment ready, we can now move on to the next step and install the required dependencies.
Install dependencies
To begin interacting with Koyeb Sandboxes, install the Koyeb Python SDK.
uv add koyeb-sdk
This adds the Koyeb Python SDK to the project dependencies which will be used to create and manage Koyeb Sandboxes.
In the project directory, open the main.py file and replace the content with the following code:
# main.py
from koyeb import Sandbox
sandbox = Sandbox.create(
    image="python:3.12-slim",
    instance_type="small",
    wait_ready=True,
    env={
        "ANTHROPIC_API_KEY": os.getenv("ANTHROPIC_API_KEY"),
sandbox.exec(
    "pip install claude-agent-sdk",
    timeout=300,
    on_stdout=lambda data: print(data.strip())
content = """
import asyncio
from claude_agent_sdk import query, ClaudeAgentOptions
async def main():
    options = ClaudeAgentOptions(
        system_prompt="You are an expert Python developer",
        permission_mode='bypassPermissions',
        cwd="/workspace"
    async for message in query(
        prompt="Create a simple Python script that writes 'Hello, world!' to a file /workspace/hello-world.txt and execute it without asking",
        options=options
        print(message)
asyncio.run(main())
fs = sandbox.filesystem
fs.mkdir("/workspace")
fs.write_file("/workspace/agent.py", content)
# Create a non-root user to bypass the `--dangerously-skip-permissions` restriction
sandbox.exec("useradd -m agent && chown -R agent:agent /workspace",
    on_stdout=lambda data: print(data.strip()))
sandbox.exec(
    "su agent -c 'python /workspace/agent.py'",
    timeout=300,
print(fs.read_file("/workspace/hello-world.txt").content)
sandbox.delete()
What the script does
  • Creates a new Koyeb sandbox using the python:3.12-slim as the base image on a small instance type (1 vCPU, 1GB RAM)
  • Installs the Claude Agent SDK
  • Copies a simple Claude Agent SDK script to the sandbox filesystem at /workspace/agent.py, which creates and executes a Python script that writes 'Hello, world!' to /workspace/hello-world.txt
  • Executes the python /workspace/agent.py command to run the agent
  • Reads the content of the /workspace/hello-world.txt resulting from the execution of the Python script performed by the agent
Before running the script, set the following local environment variables:
  • The Koyeb API token is used to create and manage Sandboxes
  • The Claude API key is used to use the Claude Agent SDK
In your terminal, run the following command to set the environment variables:
export KOYEB_API_TOKEN=<YOUR_KOYEB_API_KEY>
export ANTHROPIC_API_KEY=<YOUR_ANTHROPIC_API_KEY>
Replace <YOUR_KOYEB_API_KEY> and <YOUR_ANTHROPIC_API_KEY> with your actual Koyeb API key and Claude API key respectively.
With everything ready, we can now execute the script to deploy a Koyeb Sandbox and run the Claude Agent SDK powered agent.
In your terminal, run the following command to execute the script:
uv run main.py
The script outputs the content of the /workspace/hello-world.txt file resulting from the execution of the Python script performed by the agent.
Upon execution, the following output is produced:
Hello, world!
After the execution completes, the script automatically deletes the sandbox. You can also delete sandboxes manually from the Koyeb control panel.
In this guide, we showed how to use the Claude Agent SDK with Koyeb Sandboxes to build a minimalistic AI agent that can execute code in a sandboxed, isolated environment. We demonstrated how to turn natural language queries into Python code and execute it securely, returning results safely in a fully sandboxed environment.
Next steps
