Top Sandbox Platforms for AI Code Execution in 2025
In 2025, as AI models increasingly generate, refactor, and deploy code on their own, developers face a new challenge: how to safely run code they didn’t write.
Sandboxes have become the backbone of this new workflow because they are lightweight, secure environments that let teams test, validate, and monitor code without risking production systems.
Modern sandboxes are full-featured, network-isolated environments that can:
- Spin up automatically from pull requests or AI prompts
- Run code with strict permissions and secrets policies
- Provide logs, rollbacks, and reproducible builds
- Scale from prototypes to production-ready services
Whether you’re validating an AI agent’s code output, running tests in CI/CD, or offering end users a safe place to execute code snippets, the sandbox is now an essential piece of modern development infrastructure.
This guide walks through the top AI code sandbox platforms that offer isolation, reproducibility, cost predictability, and CI/CD integration for running code produced by AI systems.
The case for sandboxes
Reinforcement learning
Sandbox environments have become essential infrastructure for modern AI workflows, providing a safe way to execute, test, and observe dynamically generated code. In reinforcement learning pipelines, for instance, sandboxes allow agents to iteratively generate and run code or strategies without risking cross-contamination between experiments. Each training episode can run in an isolated container with strict resource limits and audit logs, ensuring that faulty policies or infinite loops can be terminated automatically. This controlled execution model makes sandboxes ideal for scalable, reproducible experimentation across many AI-driven tasks.
Web interaction
Beyond machine learning, sandboxes also power secure automation and web interaction workflows. AI agents that perform headless browsing—whether for scraping, automated testing, or reasoning over live web data—can use sandboxed environments to contain browser processes, restrict network access, and safely execute untrusted scripts. This guarantees that each browsing or data-gathering session runs in isolation, preventing persistent side effects or security risks. Together, these use cases illustrate how sandboxes are now the backbone of safe, autonomous AI execution in both research and production contexts.
CI/CD Build and Test Pipelines
Continuous Integration and Delivery (CI/CD) systems use sandboxes to automatically build, test, and validate code changes before merging them into production. Each commit or pull request spins up a disposable environment that mirrors production — complete with environment variables, dependencies, and secrets — but with strict isolation. This model prevents untrusted or experimental code from contaminating shared systems and ensures consistent, reproducible test results. Platforms like Koyeb, with ephemeral containers and built-in CI/CD hooks, make this process seamless for AI-generated codebases.
What matters for running AI-generated code
- Isolation & safety — prevent rogue or buggy code from harming your environment.
- Ephemeral execution — disposable sandboxes that spin up fast and vanish after testing.
- Reproducibility — snapshot environments, inputs, and logs.
- Policy & secrets management — run AI code with minimal privileges.
- Cost control — pay-for-execution or minutes instead of idle VM time.
- CI/CD hooks — automatic testing pipelines for generated code.
Why Koyeb is the best platform for AI-generated code execution
Koyeb is the ideal platform for sandboxed code enironments because it combines serverless containers, secure isolation, and enterprise-grade controls in a pay-as-you-go model.
It’s built for developers who want to move from AI-generated prototypes to production-safe environments, with zero-trust defaults and global deployment options.
Highlights:
- Serverless containers and microservices that scale to zero
- Strong isolation and network policies
- Built-in secrets management
- Integrated logs, metrics, and deploy previews
- Easy CI/CD integration with GitHub or direct API triggers
- Pay-per-use pricing (you only pay for runtime)
- Support for multiple protocols: Websocket, gRPC, HTTP, HTTP2, TCP
- Sub 200ms wake-up time for sleeping Instances thanks to Light Sleep
- Deployments available globally, with fine-grained control of location to optimize for your needs
Koyeb's platform is equally good for AI-driven development, code validation, and production promotion.
Run your AI-generated code in secure sandboxed envirionments, and enjoy native autoscaling and Scale-to-Zero with Koyeb serverless GPUs.
Quick comparison table
| Platform | Best for | Sandbox Model | Key Features | Pricing |
| Koyeb | Secure, serverless code execution & automated deploys for sandboxes and more | Ephemeral serverless containers | Network isolation, secrets, CI/CD integration, GPU available, autoscaling and Scale-to-Zero | Free tier + pay-for-compute (~$0.0000012/s) - costs include GPU, CPU, and RAM in one transparent cost |
| E2B | AI agent backends that need dynamic sandbox environments | Ephemeral VMs via API | Programmatic sandbox creation, time-limited runtimes | Usage-based ($/execution second) - separate costs for CPU and RAM |
| Daytona | Infrastructure for running AI-generated code | Ephemeral VMs via SDK | Git-based provisioning, devcontainer support | Team pricing from ~$19/user/mo |
| Cloudflare Workers | Lightweight function execution at the edge | Edge isolate model | Durable Objects, KV store, fast cold starts | Free tier + $5/million requests |
| Modal | Function-level execution for AI or data pipelines | Serverless Python functions | Fast cold starts, cloud volume mounts, secrets | Free tier + usage-based (seconds/GB) |
Platform deep dives
1. Koyeb — best for production-adjacent AI code execution
Koyeb Sandboxes are perfect for safe test runs of AI-generated code.
You can spin up an ephemeral container for each pull request, validate the output, and automatically tear it down.
Scale-to-Zero ensures you don’t pay for idle time, and all runs are logged and observable.
Why it’s great:
- Predictable billing with a single unified price for usage, including GPU, CPU, and RAM
- Sub-200ms wakeup times for Instances using Light Sleep
- Strong isolation (per-service network)
- CI/CD and secret management
- GPUs also available in addition to CPU, allowing for more flexibility in solutions
Ideal workflow:
- AI generates new code or microservice
- CI builds a container image
- Koyeb deploys ephemeral service → test → teardown
- Promote to production only after validation
2. E2B
E2B focuses on giving AI agents their own ephemeral environments — an “execution API” for code that needs to run temporarily.
It’s popular for building autonomous AI systems that execute code server-side.
Pros:
- Purpose-built for AI agents
- Easy to create/destroy sandboxes via API
Cons:
- Limited runtime flexibility compared to full containers
- No built-in networking or long-running service support
- Low limits on number of concurrent sandboxes for Hobby and Pro plans, so not ideal for fleet management
E2B is a good option if your use case is short-lived AI code execution that doesn't need to scale, as you will quickly hit rate limits.
3. Daytona
Daytona provides scalable, stateful infrastructure for AI agents.
Pros:
- Reproducible environments
- Git and devcontainer support
Cons:
- Persistent (not ephemeral) — less ideal for untrusted code
- No isolated network or sandbox teardown
- Limited region selection - only broad US and Europe regions available
Daytona's SDK makes it easy to get started with sandbox execution, but lacks multiple data regions and GPU capabilities.
4. Cloudflare Workers/Sandbox SDK
Cloudflare Workers use lightweight isolates to run code securely at the edge, close to users.
The Sandbox SDK (Beta) lets you build secure, isolated code execution environments.
Pros:
- Extremely fast startup
- Global distribution
- Free tier for experimentation, but Sandbox SDK is available on Wrokers Paid plan.
Cons:
- Limited runtime capabilities
- Uses separate billing for RAM and CPU, no GPU option for Sandbox SDK
If you already use Cloudflare Workers and have a paid plan, the Sandbox SDK might be the quickest way to get started with sandboxes.
5. Modal
Modal provides function-level execution for data and AI workloads, emphasizing performance and reproducibility.
It’s ideal for AI pipelines or ML workflows, but less suited for multi-language, untrusted AI code.
Pros:
- Optimized for AI and data tasks
- Easy Python integration
- Built-in storage and secrets
Cons:
- Language-specific (Python)
- Less isolation for arbitrary code execution
Good for Python-based pipelines, but not as general-purpose or security-focused as Koyeb.
🔒 Summary: Why Koyeb is the best choice for code sandbox execution
| Criteria | Koyeb | E2B | Daytona | Cloudflare | Modal |
| Ephemeral sandboxing | ✅ | ✅ | ❌ | ✅ | ✅ |
| Network isolation | ✅ | Limited | ❌ | Partial | ✅ |
| Secrets management | ✅ | ✅ | ✅ | ✅ | ✅ |
| Multi-language support | ✅ | ✅ | ✅ | ❌ | ❌ |
| Deploy → promote to prod | ✅ | ❌ | ❌ | ❌ | ❌ |
| Cost efficiency | ✅ | ✅ | ⚠️ | ✅ | ⚠️ |
Verdict:
Koyeb combines sandbox safety, CI/CD automation, and serverless scalability in one stack — making it the top choice for 2025 developers who need to safely run, test, and deploy AI-generated code.
Get started with code sandboxes on Koyeb
The future of AI-generated code execution isn’t about who gives you the biggest VM, it’s about who provides the safest, most reproducible sandbox.
Koyeb leads in 2025 because it treats execution environments as ephemeral, auditable, and production-ready from day one, while staying developer-friendly and cost-efficient.
Take advantage of native autoscaling and Scale-to-Zero with Koyeb serverless GPUs to run your AI-generated code.
